Chevy K10 Brx01 AWB
FREEDOM83
Gegeven waarderingen: 359 keren
Ontvangen waarderingen: 327 keren
Chevy K10 Brx01 AWB
Bericht door FREEDOM83 » 18 sep 2026 11:16
Good morning. Although I’ve always liked the Zil 130, the steering angle is severely limited with the tires I want to use—they rub against the leaf springs, the BRX80 axles, and the steering knuckles; adding wheel spacers improves the turning angle but causes excessive rubbing.
So, I’ve decided to modify the chassis Wwith 2XL rails and a BRX90 axle conversion kit; it’ll be fitted with an RC4WD K10 body. I’ll keep you posted on the progress.
For now, it’s time for a cleanup—once I removed the body, I realized I hadn't even seen half the grime that had built up in there—and then I'll assemble the chassis parts.
It’s been an entertaining morning; I had to reposition the servo winch and print a receiver box, but it’s all set for when the body arrives. Honestly, having a printer right there—along with a community of people who design and share files—is a huge plus; it’s really cool. The side and rear mounts, as well as the electronics box, are pre-made designs I bought on Cults3D (not the free ones), but they’re well worth the cost—the fit and finish are amazing.
The 2XL chassis rails are installed, the BRX90 kit is assembled, and everything is pretty much ready to go, save for the usual final tweaks.
first steps
Dustin (21 sep 2026 11:06)
FREEDOM83
Re: Chevy K10 Brx01 AWB
Bericht door FREEDOM83 » 20 sep 2026 07:32
I got a bit carried away and didn't even take photos of the process, haha.
There are still plenty of details left to do, but I managed to finish the most important part—the one I hate the most, painting—today, while it was still sunny and warm
Dustin (21 sep 2026 11:05)
FREEDOM83
Bericht door FREEDOM83 » 20 sep 2026 07:35
Gegeven waarderingen: 160 keren
Ontvangen waarderingen: 120 keren
Bericht door Dustin » 21 sep 2026 11:06
Looking good, really like the tires also
FREEDOM83 (21 sep 2026 11:16)
FREEDOM83
Bericht door FREEDOM83 » 23 sep 2026 08:51
I still need to finish detailing the engine and the Tough Armour bumpers, but otherwise, I’d say it’s ready to test out this weekend
FREEDOM83
Bericht door FREEDOM83 » 27 sep 2026 14:16
It's out now; this chassis blows my mind... I love it.
FREEDOM83
Bericht door FREEDOM83 » 29 sep 2026 17:26
Bumpers are mounted; as expected, the front one required some modification, but it’s now solid, securely attached just the way I like it, and properly positioned. There are still a couple of details left, but I’d say it’s basically finished.
Dustin (30 sep 2026 09:52)
FREEDOM83
Bericht door FREEDOM83 » 01 okt 2026 10:26
I wasn't quite sold on the visual contrast between the sleek, tubular front bumper and the clunky, oversized, flat rear one. So, I decided to install this 3D design from Cults3D—slightly modified regarding the side height—as it seems to match the front bumper much better.
And the front tow hook has arrived, complete with the mount to cover the winch opening.
Now I just need to do something about that one last detail—it's really triggering my OCD.
Dustin (02 okt 2026 07:45)
Bericht door Dustin » 02 okt 2026 07:46
Nice and clean!
FREEDOM83 (02 okt 2026 09:05)
FREEDOM83
Bericht door FREEDOM83 » 03 okt 2026 18:07
Finally I would say it's finished hehehe
Dustin (03 okt 2026 20:14)
Gebruikers op dit forum: FREEDOM83 en 23 gasten
