Pro-Line Racing News Topic
Re: Pro-Line Racing News Topic
Bericht door Cesco » 22 okt 2020 17:05
Ook de 1.55" lijn word uitgebreid. Met de Super Swampers. In 97.8mm.
Last but not least, how about some #TinyTires?
Pro-Line is proud to announce our first ever tire for 1.55" size wheels: the legendary Super Swamper® TSL SX!
With "almost scale" not being acceptable and access to Interco's® design data, Pro-Line's engineering staff has reproduced the original Super Swamper® in a scale configuration matched by none. The new 3.85" tall by 1.45" wide Class 0 tire is perfect for those ultra-scale 1.55" wheel rigs begging for matching scale tires combined with unmatched rock crawling performance.
https://www.prolineracing.com/tires/cla ... -tires.asp
Bericht door Cesco » 22 okt 2020 17:07
En nog meer wiel nieuws. Voor de scaler bouwers die dually wielen willen.
Some all-new innovation for the #Crawler scene!
Pro-Line is proud to introduce our new #Carbine 1.9" Dually Wheels. This pair of Carbine dually wheels will go perfectly with your next military-style or extreme off-road build and will fit 4 standard 1.9" tires, 2 tires per wheel. The best part of the Carbine is the modular wheel design that allows it to be used as a single tire wheel, dual tire wheel, or you can keep adding as many tires as you want with the addition of more Carbine wheels!
The face of the Carbine 1.9" wheel features 20 small holes with molded-in bead-loc detail for a tough military look. The included scale wheel nut cover attaches with two screws and completes the rugged appearance. The Carbine Dually wheel includes two optional 12mm hex offsets to fit both straight axles and portal axles and to give you the option for a narrow or wide offset.
If you are looking for dually wheels for your build, then look no further than the most advanced wheels to date.
For more info:
https://www.prolineracing.com/wheels/ca ... wheels.asp
