Element RC News Topic
Re: Element RC News Topic
Bericht door Cesco » 30 okt 2019 12:23
Ik kwam nog 2 interessante foto's tegen. Verschil tussen Element RC Enduro en Axial frame rails.
Bericht door Cesco » 30 okt 2019 16:12
Nog twee nieuwe leveranciers voor Element RC.
Eerst, Deadlock Racing. Ze hebben 2 opties.
THE DREDGE LCG CHASSIS TIER 1
https://deadloc-racing.myshopify.com/co ... pre-sale-1
Machined Dredge LCG chassis in G10 material.
The Dredge LCG chassis is designed to be a direct in replacement for Element RC Enduro based Crawler to increase performance and allow for better link and shock geometry options.
The Tier 1 Chassis set will include
Two chassis rails
One panhard mount
Four 5mm spacers
ENDURO AXLE SERVO MOUNT
https://deadloc-racing.myshopify.com/co ... ervo-mount
This servo mount is designed for Element Rc Enduro Axles.
Included:
Servo mount
Hardware to install
Bericht door Cesco » 30 okt 2019 16:13
En ook Hot Racing heeft nu upgrade opties:
Most where the part number starts with EDR..... (exept for ones that are AE and also now Enduro parts)
https://hot-racing.com/?c=1433_Element_Enduro_RTR
EDR10PH Brass Enduro Beadlock with 20g pin drive adapter EDR
https://hot-racing.com/?partnumber=EDR10PH;c=1433
EDR10BPH Heavy Brass wheel Hub with pin drive 75g EDR
https://hot-racing.com/?partnumber=EDR10BPH;c=1433
BFR15P06 Power Up Gear adopter B4 B5 B6 Enduro
https://hot-racing.com/?partnumber=BFR15P06;c=1433
EDR13301 Aluminum Skid Plate - Enduro
https://hot-racing.com/?partnumber=EDR13301;c=1433
EDR28301 Aluminum Front & Rear Adjustable Shock Towers Enduro
https://hot-racing.com/?partnumber=EDR28301;c=1433
EDR3801 Aluminum Stealth X Center Transmission Case Enduro
https://hot-racing.com/?partnumber=EDR3801;c=1433
EDR825X55 Stealth X Drive UD3 Gear Set Machined
https://hot-racing.com/?partnumber=EDR825X55;c=1433
EDR824X56 Stealth X Drive UD2 Gear Set Machined
https://hot-racing.com/?partnumber=EDR824X56;c=1433
EDR887T 87T 48p Hardened Steel Spur Gear Asc T4B4 Enduro
https://hot-racing.com/?partnumber=EDR887T;c=1433
EDR21H Brass Front steering Knuckle EDR
https://hot-racing.com/?partnumber=EDR21H;c=1433
EDR12CH Heavy Brass Differential Cover EDR
https://hot-racing.com/?partnumber=EDR12CH;c=1433
Bericht door Wouterb » 05 nov 2019 21:22
SBG start een upgrade serie met de Sendero.
Wellicht handige tips voor bezitters van deze auto.
Bericht door Cesco » 06 nov 2019 22:21
Zoals sommige weten werkte ik al een tijdje aan een aantal accessoires voor de Element RC Enduro Sendero.
De roll bar waar ik aan werkte staat intussen op Shapeways in 2 varianten. Met of zonder montagepunten voor 5 lampen.
Een derde single roll bar design wordt aan gewerkt.
De roll bar heeft een aantal functies. Scale looks, bescherming bij omrollen en het verbind cab en bed van de body beter met elkaar. De V1 biedt ook nog de optie van toevoegen van Axial of Injora lampen.
CRC1022 Element RC Enduro Sendero Twin Roll Bar v1
https://www.shapeways.com/product/PW49P ... =130706617
CRC1023 Element RC Enduro Sendero Twin Roll Bar v2
https://www.shapeways.com/product/LCTBS ... =130712374
Jaap
Organizer x 1Participant x 18
Bericht door Jaap » 07 nov 2019 18:30
Ziet er strak uit frank!
Groeten uit Flevoland!
Jaap
Bericht door Cesco » 07 nov 2019 19:47
Dank je Jaap.
Jaap
Bericht door Jaap » 08 nov 2019 12:05
Even een link naar facebook m.b.t. een stevige voorbumper.
https://m.facebook.com/groups/681488232 ... 0&sfnsn=mo
Jaap
Arie Kanarie
Bericht door Arie Kanarie » 11 dec 2019 18:09
Dat is zeker een stevige bumper
Jaap schreef: ↑08 nov 2019 12:05 Even een link naar facebook m.b.t. een stevige voorbumper.
BRX01 No.975 & No.1178
Vanquish VS4-10 PRO
en meer..,
Bericht door Sander » 24 dec 2019 12:22
Vandaag zijn de Samix onderdelen besteld
END-6023 black
END-6024black
END-58 stainless
