Spektrum News Topic
Spektrum News Topic
Bericht door daniel » 27 okt 2017 19:42
Nieuwe Spectrum DX5C
Productgegevens
The amazing DX5C is the perfect savvy solution for bashers, boaters and scalers who want a staggering
list of advanced features that includes the virtually unlimited possibilities 5-channel control offers. Built
around frequency-agile, DSMR® 2.4GHz technology, you can use the DX5C in any type of surface
application, including boats. Its range and response, particularly in noisy 2.4GHz environments, are
superb. It's also backwards compatible with DSM2® and marine-specific Spektrum receivers. This means
most longtime Spektrum users can continue to use the receivers they have. They’ll only need to upgrade
if they want the robust 2.4GHz interference protection a DSMR receiver can deliver.
Fits the Way You Drive
The Spektrum DX5C has many advanced programming features. So naturally it comes with advancedlevel
ergonomics. Find the comfort fit that’s right for you with optional dropdown steering wheel to the
easy-to-read backlit screen to the large grip.
Intuitive SimpleScroll™ Programming Interface
Sophisticated programming isn't worth much if it's a pain to use. The DX5C’s SimpleScroll programming
interface makes navigating menus and changing settings as simple as 'scroll and click.' It's so easy to use,
most users can complete complex programming tasks without ever having to look at the manual.
Scaling and Trailing
For getting out in the wild, the DX5C is hard to beat. Not only do you get the versatility of 5-channel
control for auxiliary systems such as winches, lights, etc., its internal processer is extremely efficient.
You get days of use, not hours. It’s also physically lightweight so that there’s less fatigue on you during
long trips, plus it’s easy to transport with all of your rigs.
Alarms
Never worry about finding your transmitter battery totally drained again. The built-in alarm will
alert you whenever the battery voltage is low, or the transmitter is left inactive with the power on.
Servo Monitor
See all five channels at work before you even turn the vehicle on. The easy-to-use Servo Monitor system
lets you see the channels react to your commands and avoid unintentional interaction.
Wheel and Trigger Calibration
The Calibration screen gives you the ability to recalibrate the steering and throttle positions for the
ultimate in accuracy.
Re: Spektrum News Topic
Bericht door Mud monkey » 27 okt 2017 20:50
Mooi zendertje
Bericht door daniel » 27 okt 2017 21:28
Ja ik vind hem ook mooi dirk
Bericht door Cesco » 01 okt 2021 16:40
Nieuw van Spektrum. Een 2 in 1 brushless motor en ESC a la Hobbywing Fusion.
Komt in een 1400KV en 2300Kv versie. Waar de Hobbywing Fusion op dit moment in een 1200KV en 1800KV verkrijgbaar is.
Mooie optie dus. Al kan je niet helemaal eromheen dat als je de Fusion en deze Spektrum versie los van de kleur wel heel erg identiek lijken.... Wat ook al met de Spektrum versie van de Hobbywing Axe serie is. Waar niets mis mee is.
Aangekondigde retail prijs van afgerond 150 dollar. Prijzen ontlopen de Fusion dus ook niet veel. Oftewel meer KV keuze zo.
Meer informatie: https://www.horizonhobby.com/search?q=S ... qNlARnjLuo
