Gmade News topic
Gmade News topic
Bericht door zanthrax » 03 sep 2019 11:36
http://www.gmade.net/gmade-110-gs02-kom ... ab-ts-kit/
Een nieuwe variant van een bestaande kap (Komodo) op een bestaand chassis (GS02).
Het is mij niet duidelijk of hier wel de verbeterde behuizing bij zit die het overslaan van tandwielen voorkomt.
Re: Gmade News topic
Bericht door WillemH » 29 sep 2020 21:42
Er zit wat in de pijplijn:
Vind de civiele versie best interessant...
Vond nog wat aanvullende gegevens:
Feature:
STEEL LADDER FRAME
ADJUSTABLE WHEELBASE: GS02F chassis allows three type of easy adjustment of wheelbase convert kit to use any type of 313 and 324mm custom bodies. (optional link kits are sold separately)
FRONT WEIGHT BALANCE
FRONT MOUNTED MOTOR: Able to use 540 or 550 size motor with cooling fan with option. The motor is designed to mounted in front of the chassis, so it can increases more tire traction to the front side.
MULTIPLE BATTERY LOCATIONS
CHASSIS MOUNTED SERVO SYSTEM WITH PANHARD BAR
The GS02F transmission is designed to look as a real 1:1 scale vehicle, and provides the best performance according to the driving situation.
The GS02F transmission is designed to rotate the front wheel faster than the rear wheel.
BETTER STEERING RADIUS: Vehicles with overdrive on the front axle has an improved steering radius compared to non-overdrive vehicles, making it easier to control when driving on the rough surfaces.
BETTER CLIMBING: Increasing of the tire traction allows the vehicle to pass through steep slopes and obstacles without lifting the front of the body upward.
2-SPEED HI/LO TRANSMISSION
TORQUE TWIST REDUCE TRANSMISSION
EASY ADJUST MOTOR MOUNT
Dual slipper clutch
All metal internal gears
Hardened carbon steel universal joints
GA44 AXLE
KINGPIN ANGLE: Keeping the scrub radius to a minimum to let your steering servo work at it's full potential and increases the steering efficiency.
HI STEER KNUCKLE ARM: By increasing the approach angle, you can over climb the obstacles more easily than a typical trial trucks.
ADJUSTABLE CASTOR
ZERO ACKERMAN STEERING
SD SCALER SHOCK ABSORBER
MT-1904 1.9 INCH M/T OFF-ROAD TIRE
1.9INCH NR01 BEADLOCK WHEEL
BUFFALO LEXAN BODY
STEALTH BODY MOUNT
Specification:
Width : 240mm
Height : 269mm
Height(with out roof rack) : 246mm
Length : 540mm
Wheel base : 313mm
Ground clearance : 77mm
Weight (no electronics) : 2.22kg
Include:
Gmade GS02F Buffalo 1/10 TS Crawler Car Kit (1 set)
TerpstraAJ (30 sep 2020 16:37)
Creepy Crawler
Bericht door Creepy Crawler » 04 dec 2020 16:14
Die Buffalo is wel gaaf!
Wie heeft een idee waar die in Nederland besteld kan worden?
Of ergens in Europa? Ik kom niet verder dan Tamico...
Carisma SCA-1E Coyote kit
Gmade GS02f Buffalo
Bericht door WillemH » 04 dec 2020 19:03
Heb hem hier nog nergens gezien. Bij Tamico was de eerste batch binnen drie dagen uitverkocht, er is dus belangstelling...
Bericht door WillemH » 08 apr 2021 22:09
Inmiddels heeft er een kruisbestuiving plaats gevonden: er is een kit beschikbaar met de technische basis van de Buffalo met daarop de carrosserie van de Komodo Double Cab.
Cesco (09 apr 2021 08:18)
Patrick 2
Bericht door Patrick 2 » 09 apr 2021 20:46
wel kom ,
super gaaf de voertuigen .
groeten van Patrick 2
Bericht door WillemH » 06 aug 2021 14:45
Weer een nieuwe variant: Buffalo pickup...
Heeft een ietwat verdiept bed, oogt toch net even een stukje realistischer...
Mijn verlanglijstje wordt steeds langer, vind hem wel een beetje boel erg mooi...
Bericht door Mud monkey » 06 aug 2021 15:13
Een stuk beter met dat bed :clap:
Bericht door WillemH » 24 sep 2021 21:49
Tamico heeft de pick-up inmiddels op voorraad...
