Toyota Hilux 4 Door
FREEDOM83
Gegeven waarderingen: 340 keren
Ontvangen waarderingen: 318 keren
Toyota Hilux 4 Door
Bericht door FREEDOM83 » 13 sep 2024 12:50
This chose is arrived at the house today, avec pas mal de choses RC4WD.
ARB Front and Rear Bumpers Anti Roll Bars with Red Crossbow Spotlights 3 Pairs of Teraflex Twins Nitro Shocks Goodyear MTR Wheels Highlift Tank Tires rc4wd rc4wd Fridge rc4wd Metal Tool Case And I'm sure I left a few other little things out there, time to revisit and make some changes, you'll see them as always:
coopertje (30 sep 2024 08:14) • Cesco (16 okt 2024 20:27)
FREEDOM83
Re: Toyota Hilux 4 Door
Bericht door FREEDOM83 » 13 sep 2024 14:55
first extra
FREEDOM83
Bericht door FREEDOM83 » 15 sep 2024 18:57
Hoy he avanzado algo , he adelantado el winch , por lo que he atrasado el paragolpes , he quitado el kit de elevación de la carrocería , le he probado la trasera , he ajustado las suspensiones , he cambiado la electrónica por un motor Holmes 40t variador 1080 y servo srt 45kg , aún le quedan horas pero ya se ve algo
FREEDOM83
Bericht door FREEDOM83 » 27 sep 2024 08:52
As more things arrive I'm making decorations and little things
Testing wheels look
Patrick (11 okt 2024 07:57)
FREEDOM83
Bericht door FREEDOM83 » 09 okt 2024 08:54
Well, it's almost done. Although it seems simple, it took 4 hours to mount the axles with the antiwrap bars. I had to put several bushings on the rear antiwrap bar to prevent it from touching the teraflex, and the front one had to be mounted on the opposite side to which it is intended, so I modified the support and mounted one of the longer ball joints. The boom axles are in reverse with the rear ones, so in the photos the axle can be seen the other way around, but I got a normal 30/8 pinion and crown kit for the rear axle, while waiting for some slightly narrower hexagons. You can almost say that it's finished.
AfbeeldingAfbeelding
